  • Kwietnia 24, 2026, 18:23:44
Autor Wątek: jawa registration from poland  (Przeczytany 1581 razy)
frysko
  • Wiadomości: 5
« dnia: Listopada 28, 2017, 10:11:28 »
hello poland jawers,i buying jawa from poland but jawa have old registration (black number) i dont have problem with registration?
Odp: jawa registration from poland
« Odpowiedź #1 dnia: Listopada 28, 2017, 10:17:44 »
You must check regulations in your country. Registration of two stroke vehicles for the first time may be not allowed.
frysko
  • Wiadomości: 5
« Odpowiedź #2 dnia: Listopada 28, 2017, 10:28:51 »
no problem i'am from lithuania it's EU ,but (black number) is old PRL registration? in my country many jawa with old soviet union documents and have many problem with registration... i buying jawa from krakow long trip but jawa very good and proce 3200zl :)
« Ostatnia zmiana: Listopada 28, 2017, 10:31:12 wysłana przez frysko »
« Odpowiedź #3 dnia: Listopada 28, 2017, 10:34:19 »
Ask lithuanian authorities in charge of vehicle registration. Peple from Poland are not familiar with regulations in your country.
  • Wiadomości: 889
« Odpowiedź #4 dnia: Listopada 28, 2017, 11:08:33 »
Black numbers are still valid in Poland so if situation with the rest of your documents is clear positive or negative result depends only on law rules in your country concerning two-stroke machines registration process.
Tjack
  • Wiadomości: 37
  • Jawa 634.7+Velorex562
« Odpowiedź #5 dnia: Listopada 28, 2017, 12:42:36 »
There should not be any problems in LT to register Jawa with Polish old black numbers. We are in EU, every registered in EU vehicle with valid papers can be registered again in EU countries. Good luck!
frysko
  • Wiadomości: 5
« Odpowiedź #6 dnia: Listopada 28, 2017, 13:18:27 »
fank you for answers :) and have one question you have in poland official jawa dealers,i need parts and repair crankshaft,we have buying jawa parts but made in china many have problem with engine,noise broken and etc...
« Ostatnia zmiana: Listopada 28, 2017, 13:25:25 wysłana przez frysko »
  • Wiadomości: 3671
« Odpowiedź #7 dnia: Listopada 28, 2017, 14:39:22 »
Check this website: www.4motor.pl
They have mamy parts for jawa, Cezet, velorex.
Unfortonately I haven't got good experience with Polish jawa distribution. But this is not only my opinion...
If you want to repair crankshaft here you have very good workshopy:
http://www.dor-mar.na7.pl
« Ostatnia zmiana: Listopada 28, 2017, 14:47:03 wysłana przez Rozztocz »
  • Wiadomości: 1063
« Odpowiedź #8 dnia: Grudnia 01, 2017, 13:44:26 »
Hi!
User tjack say true - if Your Jawa have all clear with documents they can't not allowed Your motorbike to registration. Did You check numbers on plate and on motorbike frame?
« Odpowiedź #9 dnia: Grudnia 01, 2017, 14:21:24 »
Panowie, wiazaca bedzie jedynie interpretacja urzedu rejestrujacego taki motocykl na Litwie. Problemem moze nie byc czarna rejestracja ale fakt, ze Jawa nie spelnia obecnych wymogow emisji gazow spalinowych i nie moze byc zarejestrowana na terytorium Litwy. Litewskie przepisy i ich interpretacja nie musza byc takie same jak w innych krajach.
Wpuscicie Frysko w maliny i bedzie mial do nas zal jak mu tej Jawy nie zarejestruja.
  • Wiadomości: 3671
« Odpowiedź #10 dnia: Grudnia 01, 2017, 15:06:28 »
Yabamanie Litwa jest w Unii i tak samo jak my sprowadzamy jawy z Niemiec/Czech/Wielkiej Brytanii/Francji i możemy je zarejestrować u nas w kraju tak samo i na Litwie kolega nie powinien mieć problemów...
Co innego nowe 2T. Muszą spełniać normy...
Ale najlepiej jak zapyta u siebie w Urzędzie do spraw komunikacji...
  • Wiadomości: 1063
« Odpowiedź #11 dnia: Grudnia 01, 2017, 15:23:59 »
W Unii obecnie nie zarejestrujesz nawet nowego skutera 50 cm3 w 2T. Dlatego obecnie nic nowego nie produkuje się w 2T oprócz motocrossów itp bez homologacji.
Ale tak samo jak u nas, tak samo w Niemczech itp można zarejestrować pojazd przed wprowadzeniem emisji spalin, której żaden 2T nie spełnia. Dlatego możemy rejestrować Jawki, MZtki, bo prawo w tym przypadku nie działa wstecz:) Tak samo w Niemczech jest - u nich MZty czy nawet Aprilki RS 250tki śmigają,że aż miło. Przecież w Polsce też obowiązuje norma spalin dyskwalifikująca z zakupu nowego 2T, a my śmigamy potworami kopcącymi bez żadnych problemów:)
« Odpowiedź #12 dnia: Grudnia 01, 2017, 19:28:33 »
Chodzi przeciez o rejestracje na terytorium Litwy po raz pierwszy. W Polsce mozna to zrobic, bo Jawa byla tu juz tu zarejestrowana. Jak sie litewski urzad uprze to to nie zarejestruje po raz pierwszy pojazdu nie spelniajacego wspolczesnych norm. Dlatego lepiej zapytac tego Urzedu.
sibert
  • Wiadomości: 372
« Odpowiedź #13 dnia: Grudnia 01, 2017, 19:44:47 »
Na terenie UE obowiązuje swobodny przepływ usług i towarów. Jeśli więc motocykl jest zarejestrowany w Polsce powinni go zarejestrować w każdym państwie Unii. Jedyny problem jaki tu widzę, to taki, że pojazdy rejestrowane bodajże przed 1999 rokiem nie miały wydawanej karty pojazdu i ichni urząd może stwierdzić, że dokumentacja jest nie kompletna.
JAWA 640-1 Black Style
ROMET 50-T1
BMW R1100RT
Hubertus
  • Użytkownik techniki
  • Wiadomości: 456
  • Srdcem a rozumem
    • rumble garage
« Odpowiedź #14 dnia: Grudnia 01, 2017, 20:53:41 »
Wiec moze ja. Trzy lata temu rejestrowalem Jawe 634 z Polski w Niemczech. Brak karty pojazdu nie jest przeszkoda. Nie bylo takowej i nikt jej nie chcial. Bez tlumaczen i innych dupereli. Fakt ze trwalo to kilka godzin ale udalo sie bez wiekszych problemow.
To te rejestrowana po raz pierwszy na terenie DE nie ma nic do rzeczy. Pojazd byl juz zarejestrowany na terenie UE. Kropka.
Kawasaki GPz 750 KZ 750E
Kawasaki GPz 900 R
  • Wiadomości: 1063
« Odpowiedź #15 dnia: Grudnia 01, 2017, 20:58:08 »
Yabaman - masz rację, ale nie w Unii. Już pisałem. Nikt ci nie będzie sprawdzał spalin w gaźnikowym dwusuwie w Unii, bo prawo tego nawet nie przewiduje. Obowiązują tą Jawę takie normy spalin, jakie były w momencie produkcji tej Jawy.. Czyli praktycznie żadne:)
Jak będzie chciał uwalić mu przegląd czy rejestrację to zrobi taki "myk" ze spalinami czy nawet przywali się do kloszów o pierdołę i tyle.
